BODY ROLL
Petetherod
BODY ROLL
Hi. I've recently joined the ranks of Austin 10 owners and have only just started to drive the car. I find that the car seems to have an excessive amount of body roll in corners, is this usual or is it something that needs to be addressed through some adjustment? The car in question is a 1933 10/4.
Thanks Pete
Thanks Pete
Re: BODY ROLL
I also have a 1933 10/4 and noticed the same...quite a high degree of tilt, with a graunching noise on the side being leant into at the front occasionally occurring. I changed the front bump stops as they had disintegrated, and I can feel the difference!!! Still a fair amount of movement though!!
I thought leaf springs could be at fault but I have been assured they are normal
Petetherod
Re: BODY ROLL
Sounds very similar to my problems. Will give the bump stops a try. Many thanks
Petetherod
Re: BODY ROLL
Hi. The club hasn’t any bump stops in stock, any idea where I could get some? Cheers
Re: BODY ROLL
Alderton's list them on their websitePetetherod wrote: ↑Mon Jun 20, 2022 10:43 amHi. The club hasn’t any bump stops in stock, any idea where I could get some? Cheers
Did the club spares say when they expect new stock in?
Re: BODY ROLL
Austin 10 saloons are relatively tall for their width compared with modern cars, so body roll is to be expected to some extent. As to what is “excessive” that may be a subjective viewpoint. No Ten that I have driven or travelled in has ever had as much body roll as a 2cv or Renault 4. My two-seater has little body roll but tends to “hop” sideways at the back under enthusiastic cornering. The Cambridge has greater body roll, as you would expect, which encourages more sedate driving. Neither will corner like a MiniPetetherod wrote: ↑Wed Jun 08, 2022 8:06 pmHi. I've recently joined the ranks of Austin 10 owners and have only just started to drive the car. I find that the car seems to have an excessive amount of body roll in corners, is this usual or is it something that needs to be addressed through some adjustment? The car in question is a 1933 10/4.
Thanks Pete
Being a 1930s design (and old fashioned even then) the Ten has stiff springs with short travel at the front end. At the rear the suspension travel is greater. In my experience as a driver and passenger body roll and rubbing of tyres on the inside of the wings is usually at the rear, especially if oversize tyres are fitted on the back axle. More modern designs with IFS go the other way and provide soft springs & dampers, with long travel on the suspension and an anti-roll bar.
Shockers on the chrome-rad and early Lichfield are Andre-Hartford friction type which are stiffer than the later Luvax hydraulics. At extremes of adjustment the friction dampers can have no damping effect at all or be far too stiff.
Sorry that this does not answer your question - maybe even raises some more
Petetherod
Re: BODY ROLL
Thanks for all your help. Have ordered some new bump stops from Aldertons.
david_castle
Re: BODY ROLL
The club have been out of stock of this item for some time. I tried to order two in March no date was given so I also got them from Aldertons.
Must say the delivery from Aldertons was amazing arrived the next day.
David
David
Landymanrob
Re: BODY ROLL
Are Aldertons still going? I tried the website address and it says trouble finding that site.
Re: BODY ROLL
A trouble with the original bump stops on an Austin 10 when cornered with verve is that the spring and chassis come to a stop with a sudden bump. A solution used by one member is to fit Ford Escort rear bump stops on the front springs of the 10 as in the attached picture. These are bigger and more squidgy than the originals and provide a progressive "stop".
