Grille badge
BrianEvans
Grille badge
Post by BrianEvans » Tue Aug 22, 2023 12:39 pm
Hi there ,does anyone have an Austin grille badge for a 1937 Austin 10 Cambridge that they would like to sell ? Thank you
BrianEvans
Re: Grille badge
Post by BrianEvans » Wed Aug 23, 2023 8:03 pm
Got one sorted now through the Club spares dept. 8-)
Re: Grille badge
Post by peter_winney » Wed Aug 23, 2023 8:51 pm
That's good. Maybe I should get one!
BrianEvans
Re: Grille badge
Post by BrianEvans » Thu Aug 24, 2023 2:14 pm
Hi Peter,they are not cheap though at £40.00 😉
Brian & Jo
Re: Grille badge
Post by peter_winney » Thu Aug 24, 2023 4:00 pm
Well they are not made in china :D
BrianEvans
Re: Grille badge
Post by BrianEvans » Thu Aug 24, 2023 4:54 pm
I’ve just found out it’s the wrong size ,they are saying it’s 5”long and the one off the grille is just over 6.5” long 🙄
Re: Grille badge
Post by peter_winney » Fri Aug 25, 2023 12:03 pm
The 5" badge with holes at the ends is for the chrome rad cars. The Austin script badge on the cowled rads including the Cambridge is longer (6" the broken one I have) and does not have holes right thru the ends but is fastened from behind.
Austin script badge - front view
Austin script badge fastening
BrianEvans
Re: Grille badge
Post by BrianEvans » Mon Aug 28, 2023 9:23 pm
Ah yes that’s exactly the same as ours and ours has broke in exactly the same place.😳
Re: Grille badge
Post by peter_winney » Tue Aug 29, 2023 3:47 pm
BrianEvans wrote: ↑
I have plans to glue it with a strip behind in support but the difficulty will be fitting it to the car without removing the radiator cowling & grill
Re: Grille badge
Post by peter_christie » Tue Aug 29, 2023 4:41 pm
Peter,
you can solder them with modern low temperature solder, but the metal, Mazak, zinc based alloy must be clinically clean. I have also glued it successfully using Bondic with U/V cure, but I wouldn't bet on how long it will last 'coz the U/V can't see through the metal.
(it's OK on plastic components). Gluing the whole thing on to a piece of tinplate and cutting it out with a metal-cutting fretsaw would work.
On the New Ascot, I could reach the screws from below - with difficulty!
Peter C. [6515] (still in the land of the living, but Austinless)
