Cylinder head NUTS Austin TEn gs1 1946
Posted: Sun Dec 08, 2024 11:17 am
by Allan curtis
What would be the correct torque setting for these nuts
allan4846@sky.com 07752120069
I have been told to tighten with a spanner by feel which only comes with experience
Re: Cylinder head NUTS Austin TEn gs1 1946
Posted: Sun Dec 08, 2024 11:47 am
Hi Allen
The recommendation is to use a spanner and tighten by hand so you can feel the correct tightness. This is particularly important if you are using the old head studs, which can be easily snapped or pulled out of the block.
However if you have put in new studs and are using new nuts and washers a torque setting of 34ftlbs has been used, and dont forget to retighten after you have run the car for a couple of hundered miles (when the engine is cold).
From Bill french
Posted: Sun Dec 08, 2024 12:11 pm
by Allan curtis
Hi Bill
Thanks for the reply.I will be using the old studs and nuts so I shall use a spanner and be very careful
Allan
