half shaft
Posted: Sat Apr 02, 2022 11:30 am
by cidermaster
Hi I need to replace the nearside half shaft on the austin 12,I have undone all bolts on the flange and removed the keyway/breather ,the casing is loose but will not remove from the main casing, is there anything else ive missed. thanks
Re: half shaft
Posted: Sat Apr 02, 2022 11:49 am
If you have not done it already you need to split the axle at the centre and draw the the two halves of the axle casings off the half-shafts & differential assembly. If it will not shift then remove the two locking plates on the back of the axle (2 bolts each - one on each side of the differential - one may have a breather tube) to reveal the side-play adjustment toothed rings. The casing can be pushed off the internal bearings by judicious use of a drift and mallet on the rings, screwing them in the appropriate direction.
Re: half shaft
Posted: Sun Apr 03, 2022 12:27 pm
by cidermaster
Thanks for replying, can I just do the nearside casing and leave the main rear axle in place, or do you have to remove the rear axle from the car and split both sides . I did see the castled nut but hoped the unit would come off in one piece. Thanks
Re: half shaft
Posted: Sun Apr 03, 2022 5:27 pm
cidermaster wrote: ↑
It is possible to leave half the axle on the car but you will need space at the side to extract the full width of both half-shafts. I tried this once and found the garage wall got in the way!
