Hi all
Does anyone have a decent camshaft for sale for a 35 10 Clifton
1935 Austin 10 camshaft wanted
Re: 1935 Austin 10 camshaft wanted
Yes I can let you have a 10 camshaft. PM me your address or if that does not work email moderator@austintendriversclub.com
BTW why do you need one? They should not wear out.
Good morning
Thanks for your reply. In answer to your question why? I have the engine down on this newly acquired 10 to have new white metal bearings cast and I noticed the camshaft has one or two rough spots on the journals. As the engine is now away I cant check the block so not sure what the camshaft runs in? Are they white metal shells? Any advise welcome
Rgds
Rgds
The post 1936 camshafts run on white metal circular bearings. All earlier ones have no bearing so run on the machined holes in the block. I have never seen any significant wear in the block on the earlier engines. I have had difficulty fitting a later camshaft into a earlier block, needing long-winded use of sandpaper to get a reasonable fit, but that was only once.
Christmas Greetings
Christmas Greetings
